Sagan Technology Metro • View topic - Toontracks EZdrummer
Postby jukehouse » Tue Apr 06, 2010 7:29 pm
Anybody know if Toontracks EZdrummer works in Metro ?
jukehouse
Postby Jerm » Tue Apr 06, 2010 9:12 pm
I would imagine it does. I used to use Superior from Toontrack and it worked. Have you tried the demo?
Postby greddin » Wed Sep 29, 2010 7:35 pm
What was the verdict on EZDrummer? Did it work with Metro?
What drums are the most popular?
greddin
Postby Jerm » Wed Sep 29, 2010 8:53 pm
greddin wrote:What drums are the most popular?
I haven't tried EZ-Drummer but there are quite a few very excellent drum-based plug-ins. This topic has been discussed here.
Postby w » Thu Sep 30, 2010 2:00 am
jukehouse, yes it does work with Metro, it's just a audio drum based plug.
Are you having some special problems you could relate here and perhaps i may be of some help.
w
Postby GSpro » Thu Sep 30, 2010 8:40 am
Hello forum,
I missed this post somehow. Anyway, it works with Metro as an Audio Drum plugin, like "w" said, but it can also output to midi or, after you select the pattern you desire to use, "click-drag" in the rectangle pattern display window, bottom center and drop the pattern on a midi drum track set on CH 10.
GSpro
