Sagan Technology Metro • View topic - Which version of Metro SE for OS 9.2
Postby w » Mon Sep 07, 2009 11:30 am
Which version of Metro SE should I install to run in OS 9.2 ( Power Mac )?
w
Re: Which version of Metro SE for OS 9.2
Postby w » Tue Sep 22, 2009 6:57 am
w wrote:Which version of Metro SE should I install to run in OS 9.2 ( Power Mac )?
Well Mr. Sagan ? :(
w
Postby GSpro » Tue Sep 22, 2009 10:45 am
Hi W,
I don't think Metro for OS 9 is supported anymore. The latest version for that particular system I believe it was 6.3.3 and earlier.
Maybe I'm wrong. Good luck
Gspro
GSpro
