Sagan Technology Metro • View topic - how to know a crash reason ?
Postby françois » Fri Jan 02, 2009 5:53 pm
hello, I'm under leopard, and would know how is it possible to read the crash log ?
my metro app is crash, and I don't know why
thanks
Postby almapercus » Sat Jan 03, 2009 10:34 am
Quelle version de Metro?
Robert
almapercus
Postby françois » Sat Jan 03, 2009 5:09 pm
sympa d'avoir quelq'un qui parle français....
j'ai 1 powerbook G4 ( PPC sous panther ) et un mb intel sous leopard ( tous les 2 sous metro 6.4.6 )
c'est en copiant ( en bundle ou pas ) du PPC vers le macintel que j'ai obtenu un crash - souvent répeté.... au moment du début de la lecture.
ça ne le fait pas tout de suite, mais quand je passe rapidement d'un titre à l' autre.. la roue de mets en route....et..... crash....!!!
sais tu comment on retrouve un crash log ? afin de communiquer à J. sagan les éléments expliquant la raison du crash ?
merci pour ton aide
François
Postby almapercus » Sun Jan 04, 2009 1:29 am
C'est dans Applications>Utilitaires>Console.
Bonne chance!
Robert
almapercus
Postby Jerm » Sun Jan 04, 2009 3:06 am
Can you email me the log (from the console, crash reported)?
Not Metro
Postby Jerm » Sun Jan 04, 2009 1:23 pm
For the record, the crash log points to the audio_hijack_server as the culprit and not Metro.
If you are brave you can try the latest version of Audio Hijack Pro, which is 2.9. It appears that you are running 2.1.
The use of third party audio extensions can sometimes wreak havoc on your system, especially when the operating system is updated, because the authors of that third party system have to write some officially unsupported computer code to work at such low levels.
Postby Jerm » Mon Jan 05, 2009 5:17 pm
François's problem has been solved via Rogue Amoeba tech support....
The problem that you are seeing is most likely related to the optional Instant Hijack component of Audio Hijack Pro (aka Hermes). To remove it, select "Install Extras..." from the Audio Hijack Pro menu. Then under the Instant Hijack Tab, click Uninstall. Metro will probably work just fine after that.
Users browsing this forum: Google [Bot] and 4 guests
