Sagan Technology Metro • View topic - The Duration dialog box
Postby Hiro » Tue Jul 10, 2007 5:42 pm
The tab key does not function on button. ( v6.3.3 to v6.3.8.6 upgrades)
Hiro
Postby Jerm » Wed Jul 11, 2007 12:09 pm
I am not sure what you mean. The tab key works to move to the next field of the dialog for me. Please clarify and specify what hardware you are using and what operatin system.
Postby Hiro » Wed Jul 11, 2007 6:19 pm
In v6.3.3, the tab key works to move to both field and button.
But v6.3.8.6, only to the next field of the dialog. I have to click the button.
G5 Dual 2 GHz PowerPC 10.4.10
Hiro
Postby Jerm » Wed Jul 11, 2007 7:54 pm
The dialog was changed to support OS X better. There may be a way to configure OS X so that the tab key (or other key) selects buttons using easy access or the equivalent.
Why not just use the enter key for 'OK' and the esc key for 'Cancel'?
