Sagan Technology Metro • View topic - Drumsets with drumwerks.com
Postby françois » Sat Apr 07, 2007 12:00 am
hello,
someone can tell me how can I play by midi those wav sounds ?
thanks
François
http://www.drumwerks.com
Postby Jerm » Sat Apr 07, 2007 10:18 pm
It looks like you will need some kind of sampler since the files are provided in .wav format. I can recommend iDrum since they say it is compatible. I would imagine also that IK Sampletank would work as well. I emailed the author for their free sample set so I will do some more analysis and let you know.
Postby Jerm » Sun Apr 08, 2007 11:55 am
I wasn't able to load certain of the sample samples into iDrum. I think iDrum may have a problem loading certain 24 bit audio files at this time. Sampletank converted them fine but it is difficult to control which samples are assigned to which MIDI pitches. This could be fixed by renaming the wave files I believe.
Postby françois » Wed Apr 11, 2007 5:01 pm
do you know drumagog ?
http://www.drumagog.com/
