Sagan Technology Metro • View topic - Metro SE 6.0.5 does not allow fader automation...
Postby sseaton » Tue Apr 22, 2003 1:47 pm
I can't get Metro SE version 6.0.5 to record fader movements. I can draw them in the Graphic Editor, but I can't actually record the movement with the faders.
I downloaded the full Metro Demo version 6.0.5 and had no problem with automation. I then downloaded the Metro SE Demo and reproduced the same problem described above.
I'm guessing that there is a problem with automation in the SE version.
:cry:
sseaton
Postby Jerm » Tue Apr 22, 2003 2:49 pm
I will check into this. SE does not support EFX automation but should support volume/pan automation.
Postby Jerm » Tue Apr 22, 2003 3:14 pm
Yes. This is a bug. It is fixed in 6.0.7 which will be released within the next week or so, perhaps even as early as tomorrow.
Postby sseaton » Tue Apr 22, 2003 3:22 pm
You da man, Jerm! :D I will be the first to download 6.0.7!
Sean
sseaton
