What is the difference between copying (duplicating?) a track, which i forgot how to do, and mix to track.
I wanted to double the sound, and when I did so with mix to track, the sound was reicher, but the tracks were not identical.
The original track was recorded at 44.1/16 ( I should have used a higher setting, but as I like the recording, I am keeping it.
the mix-to-track track actually sounds worse...perhaps because I used 88.2 and 24, which I probably shouldn't do unless the original was the same.
But for what it is worth, wwhat are the advantages to each method, and when i have the final two duplicated tracks, overall volume is louder so I have to
make the faders adjusted.
Fuinally, when setting the faders for MIX TO FILE (end step) or just listening, there are two faders, right? I have two identical--more or less-sereo tracks and a single fade for them. Plus the master.
Is there an advantage to the single fader being lowered and the master kept at full position? Or the reverse? This is to avoid peaks that clip. But
I GUESS the former is better?
Thank you.
