Sagan Technology Metro • View topic - video effects ?
video effects ?
video effects ?
Postby Gerald angus » Sat Dec 23, 2006 4:23 pm
In the description promos for Metro it says this:
"The video system uses Apple's QuickTime technology for recording, applying video effects and overlaying text."
Can someone direct me to where I might find more details about what this is refering to.
thanks
Gerald angus
Postby Jerm » Sat Dec 23, 2006 6:41 pm
If you have the full version of Metro you should be able to import a Quicktime movie (although this may be broken in the last pre-release). Then if you select the video (movie) track there is a menu options under 'edit:video:transition and effects'.
Postby Gerald angus » Sat Dec 23, 2006 7:06 pm
The most current version I have is G4 6.2.1
I tried the import a movie and any QT ".mov"s stayed grayed out.
Is my version up to the task?
seems not.
thanx
Gerald angus
Postby Jerm » Sun Dec 24, 2006 2:58 am
That bug appeared I think when Apple released 10.4 Tiger. However you should be able to work around it by dragging the movie to the Metro Icon in the dock.
cool
Postby Gerald angus » Sun Dec 24, 2006 12:45 pm
Just Amazing.
The /drag-drop/ worked fine.
Can't wait to see what can be done with this.
Got any pointers to more info.
I'll check the Metro Docs then play some more with it.
Can it record video/audio?
Thanks.
Gerald angus
Re: cool
Postby Jerm » Sun Dec 24, 2006 1:11 pm
Gerald angus wrote:Got any pointers to more info.
This page has some information on Metro's video capabilities. Specific (but limited) documentation on the effects can be found here.
Gerald angus wrote:Can it record video/audio?
Yes.
Good Stuff
Postby Gerald angus » Mon Dec 25, 2006 7:37 am
Thanks, will explore..........
Happy Holidays there
Gerald angus
Postby fastlanephil » Thu Dec 28, 2006 11:35 pm
Jerm wrote:If you have the full version of Metro you should be able to import a Quicktime movie (although this may be broken in the last pre-release). Then if you select the video (movie) track there is a menu options under 'edit:video:transition and effects'.
It's broken all right. If you try to import a movie into Metro 6.3.8.1 Metro goes bye bye. I just tried it as a test. I'm sure a fix is on the way.
Postby Jerm » Thu Dec 28, 2006 11:56 pm
fastlanephil wrote:I'm sure a fix is on the way.
6.3.8.2 definitely fixes this and makes movie making a little more friendly as well.
