Sagan Technology Metro • View topic - DMX
DMX
DMX
Postby françois » Sun Sep 10, 2006 2:15 pm
hello,
Could someone tell me if it's possible to control Dmx light with some plugs or programs in Metro ?
Postby françois » Thu Sep 14, 2006 12:49 am
nobody uses or is able to talk about dmx ?
Postby MP » Thu Sep 14, 2006 4:48 pm
Hi françois,
I'm not that familiar with DMX lighting, but I believe that most consoles are midi capable. If you have one that is, and it can be configured to respond to Continuous Controllers, you could use Metro's track automation to control it. You can also assign a Fader in Metro to send Midi CCs (and other data) through an external midi interface. Hope this is helpful.
Mike
MP
Postby MP » Thu Sep 14, 2006 4:56 pm
You can also place Midi CC data within a sequence to trigger the device at a specific point in time. Some DMX consoles can also sync to an external midi clock, so your lights can easily follow the tempo of your Metro project.
Mike
MP
Postby françois » Fri Sep 15, 2006 12:11 pm
yes it's nice to have lightings following the bass drum or the snare drum for exemple.
Do you now if it exist some dmx mac applications ?
Postby MP » Fri Sep 15, 2006 12:32 pm
Give this one a try:
http://www.arkaos.net/software/vjd_description.php
Also, I'll bet there are some MAX/MSP patches out there.
Mike
MP
Postby françois » Sat Sep 16, 2006 5:00 pm
I found this one, but don't knwo if it can be synched with metro.
http://www.alienapparatus.com/products.html
