Sagan Technology Metro • View topic - METRO LX 6.36 INSTALLER
Postby w » Mon Aug 14, 2006 1:03 pm
I just download Metro LX 6.36 Installer ( Download Metro LX UB prerelease version 6.36 ).
It actually installed Metro LX 6.3.5.3.
Incidentally, the SE download version is OK.
w
Postby Jerm » Mon Aug 14, 2006 1:07 pm
Checking into this....
Postby Jerm » Mon Aug 14, 2006 1:11 pm
If you look in the about box of LX it says Metro 6.3.6. It only says 6.3.5.3 in the finder's get info. This will be corrected shortly.
Postby Jerm » Mon Aug 14, 2006 1:29 pm
This problem has definitely been corrected now.
Postby w » Mon Aug 14, 2006 1:43 pm
Thanks for your prompt attention.
All is well now with the version I downloaded and installed.
And yes, it was the finders info I was checking. Should have launched the application. Sorry for my panic.
w
