Sagan Technology Metro • View topic - MIDI Newbie
MIDI Newbie
MIDI Newbie
Postby AUtech » Fri Aug 11, 2006 7:56 am
Hi I am a new tech with a university and was recently put incharge of setting up a MIDI lab for the music department. We are running Metro 6 on Intel -based Mac Minis and are using Motu USB/Midi interfaces to connect to a Roland XP-30 keyboard. I have setup the MIDI using Audio MIDI Setup in OSX and it tested OK but when I try to use the Roland through Metro, it does not recognize that it is receiving MIDI input. I know nothing of MIDI or of the Metro program really and could use a hand getting it running. Anybody want to walk me through it?
AUtech
Postby Jerm » Fri Aug 11, 2006 1:16 pm
If it tests ok in AMS then you probably need to make sure that in Metro's MIDI Setup you have XP-30 selected in the record from popup.
Also, to see input you will need to select XP-30 as an output for track 1 in the tracks window and record-enable track 1.
