Sagan Technology Metro • View topic - Roland JV1080 instruments download?
Postby SongORoland » Mon Jul 03, 2006 3:24 am
I have a Roland JV1080 with several expansion cards. Is there any way to pull the instruments onto my Mac hard drive to use internally?
Sending signals and inputting from the synth is a pain -- not a big pain -- but I would like to avoid cables and all that.
Thanks.
SongORoland
Postby GSpro » Mon Jul 03, 2006 10:40 am
GSpro
Postby Jerm » Mon Jul 03, 2006 1:46 pm
If you want to record audio you will need to feed the audio output of the hardware synth into your computer. There is no other way unless Roland has a soft-synth that I am unaware of.
Postby SongORoland » Mon Jul 03, 2006 10:01 pm
Yeah, I was getting at dumping my JV1080's voices onto my computer in a 'soft synth' type of thing, though I couldn't recall the term.
Can't be done, eh? Too bad. Where are my cables then? That was rhetorical.
Thanks though.
SongORoland
