Sagan Technology Metro • View topic - Feature Request
Feature Request
Feature Request
Postby GSpro » Sun Mar 05, 2006 12:28 pm
1# When hit Return and Forward on the Transport Panel, How about having Track and/or Graphic, Event Windows scroll at the same time?
Right now the setup is: pressing Return will start from the top. So if any changes need to be made in measure 1 for exemple, will need to hit Play and than Stop.
GSpro
Postby Jerm » Sun Mar 05, 2006 1:08 pm
Yes. This is true it should do that. Note that the return key will return to at least the graphic editor, to the beginning.
Postby Jerm » Sun Mar 05, 2006 1:55 pm
This feature is implemented in 6.3.5. The 6.3.5 pre-release will be the first Metro versions with support for Intel macs. It should be available within a week or so for free (at least for now) to registered users. OS 9 support has been dropped.
Postby GSpro » Sun Mar 05, 2006 3:41 pm
<Yes. This is true it should do that. Note that the return key will return to at least the graphic editor, to the beginning.>
No. That doesn't work either.
BTW
I'm running Metro LX 6.2.2. Metro LX 6.3.3 Prerelease I was having quite a bit of crashes today so I uninstalled it. I don't really know if I can have or run one or the other. If yes I'll install it again and send you a crash log throughout the experimentation.
Keep up the good work and thanks for the prompt reply
GSPro
GSpro
Postby Jerm » Sun Mar 05, 2006 4:45 pm
GSpro wrote: I'm running Metro LX 6.2.2. Metro LX 6.3.3 Prerelease I was having quite a bit of crashes today so I uninstalled it. I don't really know if I can have or run one or the other. If yes I'll install it again and send you a crash log throughout the experimentation.
Well, the new pre-release fixes quite a few problems so you might want to wait for that. You can run both. If you go to the console you can email me the crash logs if you like.
Postby Jerm » Sun Mar 05, 2006 5:56 pm
GSpro wrote:<Yes. This is true it should do that. Note that the return key will return to at least the graphic editor, to the beginning.>
Are you sure you are pressing the 'return' key on your apple macintosh keyboard?
Postby GSpro » Sun Mar 05, 2006 6:18 pm
My fault sir.
I was using the mouse.
The return key does the trick and works in Graphic, Event and Track window. My apology. :oops:
Thanks again for the quick reply
GSpro
