Seems that you need the original LM4 mk2 CD to update to an OS X version.
Also a question for Jerm - I may be getting hold of an LM4 (mk1) Vsti CD in a few days. Should it work in Metro 6 under OS 9?
simon201 wrote:Seems you are right Scooterman. I got a lend of an LM4 which appears to load up ok and it opens up with its own window, but when I choose one of the available kits that come with the LM4 the actual drum samples don't seem to load, and underneath each drum stays written 'xxxx'. However the information from the LM4 drum kits loads in as I notice that the volume/pan sliders change as a different kit is chosen.
