Sagan Technology Metro • View topic - playing AIFF files with my keyboard
Postby françois » Mon Dec 19, 2005 12:48 pm
Could someone how is it possible to play AIFF, or MP3 files with my midi keyboard ?
thanks
François
Postby Jerm » Mon Dec 19, 2005 1:13 pm
With a plug-in sampler that support those formats. I do not know of a sampler that supports MP3 but it is easy to convert Mp3 to aif. There are many sampler plug-ins out there (e.g. Sampletank 2, VSamp, etc.)
Postby françois » Mon Dec 19, 2005 1:52 pm
is it possible with DLS MUSIC DEVICE ?
Postby Jerm » Mon Dec 19, 2005 1:55 pm
Yes, but you will need to find a utility to convert the .aif or .mp3 into a .sf2
Postby MP » Mon Dec 19, 2005 10:58 pm
I use VSamp - it's cheap, stable, and easy on the processor. It can use AIFF files natively - to use MP3s, convert them to AIFF files in iTunes. If for some reason you must create a soundfont file, your options are limited. The only one I know of for OSX is PolyPhontics:
http://sonicamigos.com/polyphontics.php
If you have Virtual PC, you can use Vienna Soundfont Studio:
http://www.soundblaster.com/soundfont/downloads.asp
Good luck!
Mike
MP
Postby françois » Tue Dec 20, 2005 2:03 am
does Vsamp also recognive wave files ?
Postby MP » Tue Dec 20, 2005 1:24 pm
Yes, it reads .wav, .aiff, and sdII formats. You can also load soundfonts (but not create them). It is very easy to map samples accross the keyboard and you can layer samples for velocity switching, etc. Not bad for $39. You can read more about it at:
http://www.vsamp.com
Good luck!
Mike
MP
