Sagan Technology Metro • View topic - Virtual instruments with multiple outputs
Postby Paul » Fri Jun 24, 2005 9:57 am
I forget... is it or isn't it possbile within Metro to use the individual outputs of a plugin (e.g. Kontakt 2) or is only the main output available?
If it is possible... how is it done?
Paul
Postby Jerm » Fri Jun 24, 2005 2:55 pm
I do not think that Kontakt 2 is compatible with Metro.
Yes. You can do multiple outputs, up to 16, by assigning the plug to an aux buss and then routing the aux buss outputs to other aux busses in the effects window.
Postby Paul » Fri Jun 24, 2005 3:47 pm
I have been able to get Kontakt 2 to work with Metro, no problems so far.
Could you give me a step by step instruction on how to do that thing with the aux buses and the individual outputs? How do I assign, let's say, outputs 3 and 4 of Kontakt to an aux bus?
You see, when I want to use a virtual synth, I never assign it to an aux bus, I just select it in the tracks window...
Paul
Postby Jerm » Fri Jun 24, 2005 6:10 pm
Paul,
As far as I know the problem with Kontakt 2 is that once you uninstantiate it, it will not load again.
The easiest way to get what you want is to right-click (or ctrl-click) on the plug-in in the plug-ins window and select 'multi-timbral'. Now when you select Kontakt in the tracks or graphic editor windows it will automatically load on an aux buss and will also create 16 MIDI outputs for Kontakt, freely assignable to new tracks.
To get multuple, say 8, outputs working, go to 'modify busses' from the special menu and create 4 (This will give you 8 outputs). Then in the synth/effects window click on the output popups and assign each stereo out to a unqiue (higher numbered) aux buss. You can control the return volumes with aux levels in the mixer window.
Postby Paul » Wed Sep 28, 2005 2:10 pm
Jerm,
are you working on this Kontakt 2 problem or is it already solved in the latest release? You move so fast, it's hard to keep up.
Paul
Postby Jerm » Wed Sep 28, 2005 2:22 pm
Now that I think of it I only have Kontakt 1.5 so as far as Kontakt 2 goes, I really don't know.
Postby jonathanparham » Wed Sep 28, 2005 6:17 pm
Jeremy,
Jerm wrote:Now that I think of it I only have Kontakt 1.5 so as far as Kontakt 2 goes, I really don't know.
Is this something that can be implemented? Kontakt 2 is becoming very popular -even new romplers are being made with a kotakt 2 format.
Sincerely,
Jonathan
646-234-7832
www.hollandaudio.com
jonathanparham
Postby Jerm » Wed Sep 28, 2005 8:02 pm
As far as I know Metro supports more plug-ins than any other DAW on the Macintosh platform. I cannot debug a problem in Kontakt 2 (if it exists). The developer, whom I am told is very PC-centric, would need to do that. I was a member of the Kontakt 1.5 beta test team but the bugs that I presented to them were pretty much ignored. There is really little more I can do.
Postby jonathanparham » Wed Sep 28, 2005 8:17 pm
Thanks for answering so quickly.
Sincerely,
Jonathan
646-234-7832
jonathanparham
Postby Paul » Sun Oct 02, 2005 1:11 pm
The biggest problems I found with using Kontakt 2 are that there is only one midi channel available in the outputs menu (even when multiple instruments are loaded into Kontakt 2) and outputs other than 1 & 2 are not available within Metro. These problems don't exist when using Kontakt 2 in Live or Logic Pro. Are you sure it is a Kontakt problem?
Paul
Postby Jerm » Sun Oct 02, 2005 1:21 pm
Hello Paul,
That sounds like you have not right-clicked (or ctrl-clicked) on Kontakt in the plug-ins window and selected 'plug-in is multitimbral'. After you do this, selecting Kontakt from the graphic editor or tracks window will load Kontakt on an aux buss, where you can route multiple outputs, and will automatically add 16 outputs to the outputs popup.
Postby Scoot » Sun Oct 02, 2005 3:39 pm
Jerm wrote:That sounds like you have not right-clicked (or ctrl-clicked) on Kontakt in the plug-ins window and selected 'plug-in is multitimbral'
Can this be done by default or is it off because it consumes resources - memory and CPU?
Postby Jerm » Sun Oct 02, 2005 3:48 pm
No most plug-ins are not multi-timbral so there is no point in creating 16 outputs and placing the plug on an aux buss in that case.
Postby Paul » Mon Oct 03, 2005 2:29 am
Ok... that was just plain stupid of me... :oops:
In that case, doesn't Metro support Kontakt 2? What problems do you think it might give? I haven't found them out yet...
Paul
Postby Scoot » Mon Oct 03, 2005 3:28 am
Jerm wrote:No most plug-ins are not multi-timbral so there is no point in creating 16 outputs and placing the plug on an aux buss in that case.
Well the point I was thinking of was......could metro detect a multi-timbal plugin and set it as such.
If not, how about a visible indicator in the plugins window that gives you a clue that there is a menu available instead of ctrl clicking?
These are the kind of useful features you want to be able to express to new users as easily as possible. :wink:
