Sagan Technology Metro • View topic - Unable to "Import Audio Files"
Postby Industro » Thu Jul 21, 2005 7:29 pm
I'm not sure if the cause is because of my upgrade to Tiger, my update of QuickTime, or my upgrade to the recent Metro version, but I noticed that all of a sudden, I can no longer import AIF audio files into my Metro project.
When I goto File > Import Audio File > Import Audio File, and locate a stereo AIF file on my hard drive, it is "grayed out" and I am unable to select it for importing.
This is the case with AIFF files that I had previously imported (in previous Metro/OS versions) with no problem. It appears as though Metro doesn't recognize the AIFF files as "available" or "compatible."
Am I doing something wrong or is this a bug?
Please help soon!!!
Thanks!
Industro
Postby Industro » Thu Jul 21, 2005 7:43 pm
Just to clarify, I AM able to import these AIF files when I use the File > Import Movie option. (Metro provides a dialog that states it "converts audio file").
The AIF files are audio loops that I exported from Reason. The files are shown with a "QuickTime Icon" on my hard drive. They are 16-bit, 44.1 KHz, stereo AIFF files.
Not sure what has changed, as this is the same process I have used for like a year now. Now, I noticed I can't import the AIFs that I used to.
Strange.
Any help or explanation would be appreciated. If you need additional clarification, just let me know.
I can e-mail you a sample AIF file (that isn't importing) if that would help.
Thanks.
Industro
Postby Jerm » Thu Jul 21, 2005 11:28 pm
This problem has been fixed in 6.3.2. In the meantime the workaround is to simply drop the aif file on the Metro icon in the dock.
