Sagan Technology Metro • View topic - Snap to Grid for Audio Edit Regions
Postby Industro » Fri Jan 28, 2005 7:17 pm
I'd love to see "Snap to Grid" (1/4 note, 1/8 note, etc.) when using the "Audio Edit Regions" feature in the graphic editor window.
I want to slide my audio regions into new locations within the track, but I want it to "snap" to the proper note timing (right now, it just drops anywhere I release it).
This would be very helpful for audio loops that I want to rearrange within a track.
Think Apple's "Garage Band" or "Acid" (or other "loop based" audio editors) that allow you to "drag & drop" audio regions.
Also, it would be helpful to add a feature that would "drag-copy" the region of concern (like holding down the shift or option key while dragging a region will copy/paste it to the new location).
This would be very helpful!
Let me know if this is a possibility for a future release.
Thanks Jerm.
Industro
Postby Jerm » Fri Jan 28, 2005 7:30 pm
Yes this would be pretty easy to implement.
Note that you can option drag already to make copies.
Postby Jerm » Fri Jan 28, 2005 7:32 pm
Actually it is implemented. :oops:
Simply select note edit quantization on and then select the correct note duration.... duh.
Postby Industro » Fri Jan 28, 2005 8:18 pm
Aw shucks!
It's been right under my nose for months and here I've been searching far and wide for it!
Thanks for the wake up call!
Industro
