Sagan Technology Metro • View topic - idrum
idrum
Postby Scoot » Wed Nov 24, 2004 1:59 pm
rlwilliams wrote:The GM mapping information from Glaresoft looks to only work with iDrum when it is used a standalone program, not while in use as an AU, so you'd have to set up your GM info before using in Metro. Correct me if I'm wrong.
You mean the auto setting doesn't work?
This building a drumset by setting a kick to 36 as I did was done in the AU inside metro if that's what you mean.
Previous
