Sagan Technology Metro • View topic - notation zoom keystrokes don't work
Postby niro » Sun Nov 07, 2004 4:11 am
Notes:
metro 6.22, powermac g4
The notation zoom keystrokes don't work (command+[ and command+]). Those keystrokes are actually "goto previous/next note". Notation window says these are the zoom keys, however the "Window" menu says the zoom keys are "command++ and command+-" (which don't work either).
My suggestion:
1. "command++" and "command+-" should be zoom for notation
2. keep "command+[" and "command+]" as next/previous note
niro
Postby Jerm » Sun Nov 07, 2004 3:40 pm
This problem has been corrected.
