Sagan Technology Metro • View topic - record bug
record bug
record bug
Postby kaboombahchuck » Mon Oct 11, 2004 12:38 am
In 6.2.1.7 I can record a track, or import one, and everything is fine. But when I activate the "software audio thru" I loose the ability to monitor or record another track. When software audio thru is first chosen I can hear the audio tracks previosly recorded, and can monitor what's going to be recorded (armed track) while playing the track, but then the play thru will cut out after a bit. Once I choose to record the track, nothing. I can still hear the original tracks, but no record of new track, no monitoring. Then if I turn off the play through still nothing.
kaboombahchuck
Postby Scoot » Mon Oct 11, 2004 4:03 am
I recently lost the ability to click/activate a track to record.....but I think it had to do with someone elses setup that I was looking at.....after he sent me one of his midi files.
Could also be a Jaguar hiccup.
Everything seems ok now though.
Sorry no help but I just thought I mention a recent problem. I was also low on disk space at the time.......if Metro takes notice of this fact before allowing the R to work.
Postby kaboombahchuck » Mon Oct 11, 2004 6:09 am
The thing is I did not have this problem with previous Metro updates..
I'm running Panther.
I have over 50 gigs of free disc space.
I have 1 gig of ram.
kaboombahchuck
Postby Jerm » Mon Oct 11, 2004 9:35 am
I would try turning off overload protection in general preferences after I turned down the headphones volume.
Postby kaboombahchuck » Tue Oct 12, 2004 7:12 am
I just tried that with no luck..
Looks like I'm gonna have to change the way I'm set up on the mixer.
Either that or go ahead an get that MOTU 828mkII ive been eyeballing.
kaboombahchuck
Postby Jerm » Tue Oct 12, 2004 10:48 am
Let me look into this further. Are you using any internal ports? Have you tried routing the Metronome to a MIDI device (not using the factory default)?
Postby sagantec » Tue Oct 12, 2004 12:45 pm
Scoot wrote:I recently lost the ability to click/activate a track to record...
This is probably because the track was set to movie and you do not have any video input hardware.
sagantec
Site Admin
Postby Scoot » Tue Oct 12, 2004 2:34 pm
That will be it.
From Francois's setup metro would have picked the closest choice to his audio firewire device......and I just clicked ok. :wink:
Re: record bug
Postby Jerm » Tue Oct 12, 2004 4:07 pm
kaboombahchuck wrote: when I activate the "software audio thru" I loose the ability to monitor or record another track.
if it is loose then tighten it. Just kidding. :lol:
This works fine for me in 6.2.1.7.
kaboombahchuck wrote: When software audio thru is first chosen I can hear the audio tracks previosly recorded, and can monitor what's going to be recorded (armed track) while playing the track, but then the play thru will cut out after a bit.
cut out? I am not sure what you mean.
kaboombahchuck wrote:Once I choose to record the track, nothing. I can still hear the original tracks, but no record of new track, no monitoring. Then if I turn off the play through still nothing.
Can you possibly email me the smallest compacted bundle file that still reproduces this problem? If I am able to reproduce we can fix it, if it is indeed a Metro problem.
Postby Scoot » Tue Oct 12, 2004 8:10 pm
>cut out
stop working.....no longer hear.
Probably from cars......cutting out - ignition problems - spark not getting through. :lol:
Postby kaboombahchuck » Wed Oct 13, 2004 7:06 am
Yes.. cut out / no longer hear. Seems like the VU continues working, but I'll check on that one again.
I'll work up a quick bundle and send it out. Probably 3 tracks @ ~ 30 sec. The first 2 tracks will be done without audio thu, the last with.
kaboombahchuck
Postby kaboombahchuck » Wed Oct 13, 2004 8:21 am
Ok, I sent the bundle to administrator@sagantech.com. It is ~ 6 MB and is titled Bug Bundle. I noticed when loading the bundle that software thru is not checked, but when I do select it the problem is still there.
BTW, don't make fun of it... just something I threw together. :oops:
kaboombahchuck
Postby kaboombahchuck » Wed Oct 13, 2004 8:53 am
Problem solved :oops: I put the Metro folder in HD so the metro icon would appear in the dock. I was activating metro from the dock...
When I go to metro folder and open metro from there, no problems.
kaboombahchuck
Postby Jerm » Wed Oct 13, 2004 11:02 am
Should I check out the bundle anyway or not?
Postby Scoot » Thu Oct 14, 2004 5:28 am
kaboombahchuck wrote:Problem solved :oops: I put the Metro folder in HD so the metro icon would appear in the dock. I was activating metro from the dock...
You were launching an old metro version before?
