Sagan Technology Metro • View topic - The BUG REPORT FORUM
Postby Scoot » Thu Mar 13, 2003 5:37 pm
Obviously to be used for things we can repeat over and over again in exactly the same way............so it wasn't just a system problem.
I can think of one right away.
The new demo quits when I move the dynamic plugin from the plugin window to the track window.
OS 10.2.4
Postby Jerm » Thu Mar 13, 2003 9:29 pm
I cannot repeat this. The new demo? Which version is that (From get-info)? Which plug-in are you moving? Moving? Do you mean dragging?
Postby Scoot » Fri Mar 14, 2003 6:10 am
Version 6.0.5i4 Downloaded yesterday as I just got Jaguar recently.
Double click metro
command 9
command 0
drag Apple:AU Dynamics Processor from plugins to effects and metro unexpectly quits.
If it works for you I may have a corrupt dynamics processor.
I don't know where metro is getting these plugins from as they are not in the metro folder and I have found several 'audio' and 'plug in' folders on the hard disk that are all empty.
Postby Gary K. Doty Sr. » Fri Mar 14, 2003 11:53 am
My AU Dynamics Processor also shuts down Metro 6.0.5i4.
Gary K. Doty Sr.
Gary K. Doty Sr.
Postby Jerm » Fri Mar 14, 2003 12:58 pm
These are Apple computer's built-in plug-ins (AudioUnits). Apple knows about this dynamics processor problem. I thought I had disabled the dynamics processor plug-in in 10.2.2. Perhaps it is still broken. I will investigate!
Postby Jerm » Fri Mar 14, 2003 6:04 pm
Ok. I did some investigating. The way I had decided to deal with this is to hide the dynamics processor plug-in in Metro 6 if the user is running OS 10.2.3 assuming that it would be fixed :( in any subsequent OS releases.
Please tell me what OS version you guys are running?
Postby Gary K. Doty Sr. » Fri Mar 14, 2003 7:16 pm
I am running OSX 10.2.4 and Metro 6.0.5i4
Gary K. Doty Sr.
Gary K. Doty Sr.
Postby Scoot » Fri Mar 14, 2003 10:21 pm
10.2.4
Its good to know its an apple bug and nothing you have to quickly solve in Metro Jerm.
Maybe you should write Apple's audio plugs. :lol:
Postby Jerm » Sat Mar 15, 2003 5:19 pm
Hot off the CoreAudio mailing list from Bill Stewart (Apple software engineer).
"Whilst we will fix the V1 version of this unit, there will also be a V2 version at that point anyway.
We are not doing any further development of V1 based units - as far as we are concerned they are deprecated"
Therefore, in 6.05i5 and after the buggy V1 dynamics audio unit plug-in will not appear. When the V2 version is included with an OS update, it will appear. I presume this wil be 10.2.5 but I do not know.
Postby Scoot » Tue Apr 15, 2003 3:11 am
Has the dynamics processor plug been fixed in 10.2.5?
Has anyone noticed any improvements in audio in the system update?
Postby Jerm » Tue Apr 15, 2003 8:40 am
An excellent substitute for the Apple dynamics plug-in can be found here:
http://www.sagantech.com/metroforum/viewtopic.php?t=132
