Sagan Technology Metro • View topic - Sync Metro to Roland VS-1824?
Postby maikunari » Wed Jul 28, 2004 8:35 pm
HI all,
Considering purchasing Metro and just wondering if I can sync it to my hard disk recorder, preferably using metro as the slave.
Thanks very much,
Mike
maikunari
Postby Scoot » Wed Jul 28, 2004 10:39 pm
Have you downloaded a demo and tried it?
Postby maikunari » Thu Jul 29, 2004 6:16 am
I've downloaded the demo and I like it, but I haven't got a usb-midi interface yet to try it out.
anyone tried it?
thanks,
Mike
maikunari
Postby cornutt » Sun Aug 01, 2004 10:23 pm
Does the VS output a SMPTE signal? If so, I can't think
of any reason why it won't work. I've synced Metro to
tape-track SMPTE plenty of times.
cornutt
Postby murphy » Thu Sep 30, 2004 8:09 pm
cornutt wrote:Does the VS output a SMPTE signal? If so, I can't think
Roland's VSaudio recorders can be controlled with MMC or MTC.
I work with my VS using LOGIC via MMC or MTC. Then the VS becomes an external audio card with 16 audio tracks. Which code I use depends on if I want Logic to control VS or if I want the VS to control LOGIC
Can Metro be set to use MMC or MTC to control the Roland VS audio recorder?
If so, how do I set that up in METRO?
murphy
