Sagan Technology Metro • View topic - PLug In Question
PLug In Question
PLug In Question
Postby PhilGillis » Thu Jul 15, 2004 12:16 am
I see in the Plug-Ins that I have some from APple . I guess these are AUs . .trying to learn the terminology . .anyway, here is the list I have:
Delay
Dynamic Processor
Graphic EQ
High Shelf Filter
HiPass
LoPass
Matrix Reverb
MultiBand Compressor
Parametric EQ
Peak Limiter
DSL Music Device
WHere are these actually located on the drive? I cannot find them anywhere. Are these considered Audio Unit Plugins?
Phil
PhilGillis
Postby Scoot » Thu Jul 15, 2004 7:33 am
Built into OSX I believe........Jaguar and beyond seems to be better than earlier versions.....Is it part of core audio?
Normally other audio units would be located at
harddiskname/library/audio/plug-ins/components
if you have others to install.
Metro also can use VST plugins which are alongside the components folder.......which is something Apple/Emagic seem to have ignored/replaced with AU's.
At http://www.grantedsw.com/
there is an audiounit manager that can turn them on and off, but I don't think it can change these standard plugins you mention. It behaves like the old extensions manager.
The DSLMusicDevice you have in your list is a shell to load soundfonts.
Soundfonts are better sounding instruments than quicktime and there are links to find them on the sagantech website. :wink:
My other fav is the matrix reverb and would work on audio tracks.
Postby PhilGillis » Thu Jul 15, 2004 10:33 am
trying to learn all this stuff . .changed up a lot since the old days
:lol:
PhilGillis
