by françois » Mon Feb 14, 2005 4:50 pm
For info my metro folder takes 92,68 Mo ram without holding the option key at the opening, and 87,67 Mo when I hold the option key.
Thanks jerm : 5Mo ram saved.
Could you tell me if it's possible to define a midi buffer for metro application, ( or some priority function ) when it works with other applications ??
I use Audio hi jack pro running with recordins at 24 bits/44khz for long recoding sessions ( 3 / 4 hours ) and at sometimes the counter at the transport window is running very slowly while the music sounds good. But one time metro application began to freeze and a this time metro plays always the same note, and impossible to change that without quit.
Do you know a way to rend osX more light and fast ?
I use for instance my new pb 15" 1,5 Ghz with 512 Mo and will have
soon 1,5 Go.
cheers
François
