by Jerm » Wed Jun 09, 2004 5:08 pm
Paul,
The answer is that MIDI (the notes in the MIDI file) do not describe the sound completely but rather just the pitch, duration and timing among other things. The actual waveform that makes up the sound is contained in the device producing the sound.
With that said, I think what you want to do is to select the Crystal track and then use the Mix-Or-Render-tracks from the file menu to convert the MIDI data to audio. Once it is in audio format it will always describe the same sound and will play as expected in Quicktime Player.
