Sagan Technology Metro • View topic - Input midi notes
Input midi notes
Input midi notes
Postby juanchamo » Mon Mar 15, 2004 2:10 pm
Hi,
I've been using the pencil tool to input notes into the graphic editor and I'd like to ask whether it is possible to enter tha notes in a grid mode, so that you put all the notes at the 000 of each quarter-note position automatically.
Juan
juanchamo
Postby Scoot » Mon Mar 15, 2004 2:36 pm
Just pick your note length, and then use the pencil tool on the piano roll on the left side of the graphic editor. :wink:
If the notes are too long, you could later select them all and shorten them.
Postby Jerm » Mon Mar 15, 2004 3:33 pm
Scoot wrote:JIf the notes are too long, you could later select them all and shorten them.
:idea: Or you could just set '% of value' before entering them.
Perhaps note editor quantizing is what you want.
Postby cornutt » Mon Mar 15, 2004 11:15 pm
When I want a part to be really tick-tock, what I
often do is select a note value and a starting point in
the piano roll, then I enable the keyboard too and
tap out the part on my master keyboard. This way,
you can enter chords too without any extra effort.
cornutt
Postby Scoot » Tue Mar 16, 2004 2:03 am
Is that using step recording cornutt, or just normal?
Postby juanchamo » Tue Mar 16, 2004 11:10 am
[quote="Scoot"]Just pick your note length, and then use the pencil tool on the piano roll on the left side of the graphic editor.
Hi and thanks,
I've done what you say but then you have to pick up the point when you are actually on the 000 position of each quarter note in every bar. You have to be careful and move your cross-shaped cursor slowly so that you get the correct note position. Otherwise you can put them in a slightly behind or ahead position.
I wondered whether there is a locking option so that you don't have to be that precise because the app itself puts the note exactly on every 000 spot for you.
Juan
juanchamo
Postby Scoot » Tue Mar 16, 2004 2:10 pm
I just did this quickly to show they are all locked.
Look where the cursor is.
It is ON the piano.......not in and amongst the notes you are making.
That's brilliant
Postby juanchamo » Tue Mar 16, 2004 11:01 pm
Hi!
Thanks. I got you now. That's exactly what I wanted. It's brilliant too.
Juan
juanchamo
Postby Scoot » Wed Mar 17, 2004 12:45 am
I suppose it's not obvious, but that's the beauty of a forum. :wink:
Postby cornutt » Tue Mar 30, 2004 6:54 pm
Scoot wrote:Is that using step recording cornutt, or just normal?
Sorry I haven't responded sooner... :oops: Yes, that's step recording.
cornutt
