Sagan Technology Metro • View topic - Editing controllers with the pencil tool
Postby Scoot » Wed Mar 10, 2004 3:12 am
Below is a composite of 2 graphic editor views......the pgm change editing view and a controller view.
Would it be possible to have the pencil (with a key combination) when editing a controller, behave like it does in the pgm change?
ie. breaks the line and draws another horizontal line straight across to the right.
This would make the result a little quicker and easier to do.
Or have I forgot a setting that does this?
Postby Jerm » Wed Mar 10, 2004 10:02 am
Try option or control drawing. Option locks the vertical position and control allows one to draw straight lines.
