Yes, The Roland method from Cornutt's posting of May 7 works for the Yamaha as well. I rechecked, and Metro does give a different checksum.
vicpierce wrote:Yes, The Roland method from Cornutt's posting of May 7 works for the Yamaha as well. I rechecked, and Metro does give a different checksum.
Jerm wrote:Well that is the exact code to calculate the checksum. If you want to post the sysex I will manually post the checksum that I calculate.
Jerm wrote:Vic,
As you have seen in the Cornutt thread (Cornutt will need to re-verify this), it works on his devices.
Therefore I think the correct answer is 33H. The result is 31H if you also include the 02 in your checksum but I do not think this is the way the checksum was intended. When he adds 4 to the address (which goes into the variable 'first') the F0 has already been stripped off.
Jerm wrote:Metro 6.1.0.5 will support templating by either locking the document or setting the stationery bit. These setups with outputs and/or remote control setups for a particular device would be cool templates for Metro users.
