Sagan Technology Metro • View topic - private messaging disabled
Anything to do with our main site. www.sagantech.biz
Postby Scoot » Tue Nov 18, 2003 6:56 pm
disabled from now on or a mistake?
I guess you get a lot of messages and they're slow to read.
Postby Jerm » Tue Nov 18, 2003 7:18 pm
I noticed someone was somehow hacking into the private messaging system, using it to send messages without registering so I disabled it.
Postby Scoot » Tue Nov 18, 2003 9:36 pm
I see.
Maybe if the permissions were changed so you have to log in to even read the board, it may stop the problem.
I have my forums set up so no guest can write a message (and I think the same applies here) but maybe the above solution is a little extreme.
The PM's are not really needed if people have an email.
Return to Comment/suggestions
