Sagan Technology Metro • View topic - Pausing between Sections
Postby Gbryal » Fri Nov 07, 2003 11:48 pm
When I attempt to continuously playback consecutive sections, there is a noticeable gap between them. I verified that in the Section Timing Options window I have "Wait 0 seconds..." selected. I then entered a step time midi drum beat of one measure and looped it for 8 measures. I did the same in a second section, and when they are played end-to-end, there is a pause between them.
There is no Audio yet recorded.
Copying the Sections into a new Track as Subsections eliminates the pause.
Gbryal
Postby Jerm » Sat Nov 08, 2003 1:50 pm
This is normal. If you need to have sections abut each other without delay then you need to use subsections.
