The version 6.1.0.1 pre-release is now available. Users that downloaded the 6.1 pre-release are strongly urged to download this update.
Download it here:
IMPORTANT: The official system requirements have changed. Metro 6.1 requires either OS 10.2 or later or OS 9.1 - OS 9.2.x! It is possible that Metro 6.1 will work with other OS's (such as 8.6, 9.0 & 10.1.5) but they are no longer supported.
IMPORTANT: Metro Documents written with this version will NOT be readable in any version prior to Metro/Metro SE version 6.1!
An optimization in 6.1 was removed because it was causing problems with random crashes and even a potential data corruption. If you are doing a lot of real-time MIDI edits and you find Metro to be performing slow, it is recommended that you close the notation window.
Detailed changes in this version:
• Fixed a keyboard shorcut conflict between the lyrics window and the looping dialog. The looping dialog shortcut is now Open-Apple + Ctrl + L.
• Fixed a problem where an erroneous error would occur if you tried to normalize a MIDI track.
• Miscellaneous changes to add stability to this version.
Detailed changes in 6.1
• Notation and Lyrics window in OS X.
• Notation printing in OS X.
• Notation enhancements, such as page numbers, date and time text.
• New standard saving and loading of Audio Unit presets (.aupreset files) thanks to Marc Poirier.
• New remote control events for Arming new audio track, jogging with any controller and jogging with a jog controller.
• Enhanced support for Absynth, Phatmatik Pro and other plug-ins.
• Automation problem with AudioUnits plug-ins has been addressed. Numbers typed into parameters are now automated.
• Automation displays in the graphic editor (audio units only) now reflect the exact range of the parameter shown rather than 0.0 to 1.0.
• Double-click in Notation to bring you to the same location in graphic editor (or list-editor if on in switches menu).
• Synthesizer plug-in editor windows now show unique names in the windows menu when multiple instances are in use. e.g. Absynth1, Absynth2, etc.
• Owners of site-licenses can now easily deploy Metro/Metro SE with the new Sasafrass KeyServer support.
• New ability to clear the recent items from the open and import menus.
