Sagan Technology Metro • View topic - recording with metro
Postby françois » Thu Aug 21, 2003 11:32 am
could you tell me if it's possible to record in another format than AIFF ( AAC for example ) ?
where In metro can I choose the destination audio file ?
thanks
Exporting MP4
Postby Jerm » Thu Aug 21, 2003 4:40 pm
Metro will not record directly to AAC. Metro always records in AIFF format.
Metro will export MP4's in AAC format.
1. Select the track with the audio that you want to export.
2. Select file:export-track.
3. Click Export-using-quiicktime.
4. Select the Movie-To-MPeg4 from the popup. Click options... to specify specific MPeg 4 settings.
5. Click Save.
Postby françois » Fri Aug 22, 2003 12:45 am
thanks jerm, could you also tell me how can I choose the destination folder for my audio files before recording ?
Postby Jerm » Fri Aug 22, 2003 1:20 am
Yes. You basically have two options. The best option is to simply save your document before recording. This sets the default location for storing audio files.
The other option only applies if you have not loaded or saved a document since starting Metro. In this case when you press record Metro will ask you to specify the location.
Users browsing this forum: No registered users and 12 guests
