Phil:
Thanks for the tip. I found the Behringer Eurorack MX602A in a American Musical Supply catalog for $80. Frankly, I was shocked -- err, pleasantly surprised. However, if I understand things correctly, I may not even need that - but it is nevertheless good to know for the future.
Jerm:
I obviously need to do more reading on MIDI, soundfonts and the OSX soundfont player, but I *think* I now understand what you were so patiently trying to tell me.
First, in answer to your question: The only MIDI device I was considering was a portable keyboard that I was (hopefully) going to use for rhythm (drums), bass lines and perhaps some actual keyboard stuff (heh heh). Actually, until I read about the midi drum track that Metro can create a MIDI drum track, I was planning on recording all the keyboard stuff through an audio interface (hence the Mbox) - on separate tracks. Only after I discovered Metro's drum track facility did I even think about mixing MIDI and audio tracks.
Now then, here is what I *think* I understand (please correct me if I'm wrong):
1. Metro can mix the Metro midi drum track with audio tracks because the an external MIDI device is not needed to generate the sound. (I guess the Metro drum track is done by an internal synth/sampler?)
2. If I recorded stuff from the keyboard (a MIDI device) via a MIDI interface, I would have first convert the MIDI data to audio via the MIDI device before I could mix it down with audio tracks (because Metro could not properly convert the MIDI data to audio internally - Metro would not have the keyboards sound files (or whatever you call them) ). To do this, I would have to export the MIDI data to the device, then route it back to an audio track through an audio interface before mixing. An external mixer would simplify the process.
3. It may be possible to use the OSX soundfont player in place of the keyboard I intended to buy. I may be able to use the player to create the bass lines and keyboard voices, with drums straight from Metro.
K. Now, assuming I've got that more or less right, I have a few more questions.
1. Do you have any idea where I can find out more about the OSX soundfont player? I saw the soundfonts listings in your support section and it looks impressive. Is the soundfonts player active in OSX v. 1.1x or only in Jaguar?
2. Is the player kind of like a virtual synth? If so, can you input via a MIDI controller? - (maybe something akin to the oxygen8 but hopefully with a bigger keyboard)? (I'm thinking that maybe I should be looking for a MIDI controller type keyboard rather than a portable thingy). Again, please excuse my ignorance.
(Sigh) It seems the more I learn, the more confused I get.
3. Last one (for now): Can tracks created in Metro SE be exported to Pro Tools and vice versa? The reason I ask is because I'm starting to think that maybe I should just jump on a bandwagon and learn as I go. If I got the Mbox and Pro Tools LE, I'd have a decent audio interface with compatible software. If I then got Metro SE, I could use Metro's Audio Unit and Soundfont compatibility when needed, the Mbox for recording audio, and either one for the final mix (wherever I happened to end up). I guess I might even get to the point of using the Mbox with Metro only - assuming they're compatible. I guess I'd have to upgrade to the full version of Metro, though - for the increased audio tracks. I don't think 4 audio tracks would be enough for me - for example, I would want the ability to make alternative guitar tracks just for the sake of experimentation.
Thanks once again for your patience and assistance.
