Sagan Technology Metro • View topic - Audio track playback with software audio thru on
Postby Jazzdude » Tue Jul 29, 2003 9:16 pm
This morning I discovered that when auditioning audio tracks, if software audio thru is turned on, any track which is record enabled plays back, even if the track is muted and/or archived.
This seems odd to me. I found it somewhat frustrating when trying to listen to a specific track and the record enabled track played back at the same time. It took me a little while to figure out what was happening.
The solution was simply to turn software audio thru off.
Have other users noticed this problem?
Jazzdude
Postby Jerm » Tue Jul 29, 2003 11:10 pm
Investigating.....
Fixed!
Postby Jerm » Tue Jul 29, 2003 11:59 pm
Thanks. Fixed in 6.0.8.2.
