Sagan Technology Metro • View topic - Hidden input select? Does the stereo checkbox work in 6.08?
Postby matro » Mon Jul 14, 2003 12:33 am
Thanks again for another great update, but does the "stereo" check box (in the audio setup window) still work?
If not, I don't mind now that I found the Audio Record Input Select column of the tracks window...which is actually a better Idea.
Is that column hidden by default? I just had a little confusion that others might as well.
I just wanted to record in stereo in this version...
I looked up the online help that did steer me in the right direction (with fresh new info), but I couldn't find the "Audio Record Input Select column of the tracks window" Until I clicked on the little black triangle above the track numbers. Maybe it's only my preferences that would hide it by default.
I also had a copy of 6.07, and the "stereo" check box was still working, so maybe it isn't just a glitch on my system.
-M
matro
Stereo Check box superfluous
Postby Jerm » Mon Jul 14, 2003 11:13 am
Yes. The stereo check box is now superfluous and does nothing. This will be removed soon. The way to select stereo inputs is from the Input Record Select column.
Postby Scoot » Mon Jul 14, 2003 4:11 pm
It may pay to keep this column seen at all times then.......to stop repeat questions on how to record in stereo. :)
