Sagan Technology Metro • View topic - Why would the midi tracks not cue from the beginning?
Postby NeMusashi » Fri Jun 20, 2003 10:09 pm
When I record, regardless of whether its a new midi or audio track, my previously created midi tracks will not cue from the beginning. For example, if I've created a four bar midi track, and then attempt to record another track, the midi track will start at the third bar. Note, this problem only comes up when I record, and never when I simply play back tracks. Consequently, whenever I record, I'm forced to mute all the midi tracks, otherwise I'd get lost rather quickly.
NeMusashi
Postby Jerm » Fri Jun 20, 2003 10:27 pm
I am not sure I understand. Do you have program changes in your MIDI track? What device are you using for your MIDI tracks? If you email me a Metro or MIDI file I can take a look. Please do not include audio files.
Postby Scoot » Fri Jun 20, 2003 10:31 pm
You don't have any cues, countoffs, punchins, loops, markers or overdubs happening do you?
How pure are your preferences from the original ones?
If this has only happened recently a setting must have be changed.
