Sagan Technology Metro • View topic - Error message
Error message
Error message
Postby pawright » Tue Jun 10, 2003 8:51 pm
I tried to record from my controller. I got a message that the disk was too slow to record. It did have several bars, but not the last one of 8.
I have a 1.0G G4 PowerMac with the installed 60G Hard drive. I have another one attached internally and a Firewire HD plugged in. I don't play rapidly.
Please explain the message.
pawright
Postby Scoot » Tue Jun 10, 2003 9:06 pm
Which version of metro are you running?
There are posts here about slow drive errors and one of the latest versions removes the message as it was appearing on occasions when there was nothing wrong.
check out the audio and bug report sections.
Update Version
Postby Jerm » Tue Jun 10, 2003 9:38 pm
Scoooteman is exactly correct. Please update your version to 6.0.7.3!
This sounds like you are recording audio? Do you have a USB audio device?
Shouldn't you be recording MIDI from your controller?
