Sagan Technology Metro • View topic - graphic editor
graphic editor
graphic editor
Postby françois » Thu Oct 20, 2005 6:50 am
- in the graphic editor :
when we go to the track pop up selector, would it be possible to remain the same view pop up ?
for ex, if I want to control the main volume for each track in the graphic editor, I have to select at each time the controler.
