Sagan Technology Metro • View topic - MIDI recording
MIDI recording
MIDI recording
Postby Fred » Wed Mar 12, 2003 5:54 am
Would be nice if the track VU meter shows MIDI input (like audio)
Fred
True.
Postby Jerm » Wed Mar 12, 2003 9:36 am
Very true.
Postby buserror » Wed Mar 12, 2003 7:14 pm
What about showing the notes in the graphic editor while recording? right now nothing appears until you stop recording...
buserror
Re: MIDI recording
Postby Jerm » Thu Mar 13, 2003 4:58 pm
Fred wrote:Would be nice if the track VU meter shows MIDI input (like audio)
This is implemented in 6.05i5. Please tell me though... Should the input VU reflect the state of the volume/mastervolume faders? :?:
Right now it simply shows input regardless of the volumes and I think this is correct. However this is different behavior than the other MIDI vu's in Metro.
Postby Fred » Thu Mar 13, 2003 6:52 pm
Great! I'm quite sure this is correct for input, the faders having effect only on output/playback.
Fred
Postby Jerm » Thu Mar 13, 2003 9:10 pm
Having effect or affect? :wink:
Postby Fred » Fri Mar 14, 2003 6:45 am
Good question. Admitted lack of clearness. The right term is 'reflect'.
BTW, that leads to a general question about the instruments window. I think it has great potential to act as control and display of a connected MIDI device, ie. to 'reflect' the state of the device at any time. For example it would be nice to see that on GS reset all faders go to 100, all programs to 0 etc. I regard that kind of reflection very helpful, since MIDI is *state-oriented* and it's always good to know the actual state. Partly this is already implemented and the question is how far to go ...
Fred
