Sagan Technology Metro • View topic - Request for Keyboard shortcut
Postby Gary K. Doty Sr. » Tue Nov 09, 2004 2:25 am
It would be great if there was a keyboard short cut to enter into
"Enter Chord Mode" instead of have going to the mouse every time
for each chord.
what would be even better if you have entered chord mode
you would stay in chord mode until you exit chord mode
That would really be cool!!
Gary K. Doty Sr.
Gary K. Doty Sr.
Postby Jerm » Tue Nov 09, 2004 3:08 am
Once in chord mode you can use the tab key to advance by the step duration time to enter a series of chords. You can also use command click on the pencil tool to select a chord and then command-click in the graphic editor to enter it.
Let me know if this is okay because I cannot see why you would be entering chord mode very often.
That works great!!!
Postby Gary K. Doty Sr. » Tue Nov 09, 2004 6:08 pm
Thanks Jerm,
I knew there had to be some easier way.
Gary K. Doty Sr.
Gary K. Doty Sr.
