Sagan Technology Metro • View topic - keyboard shortcut for Archive and Unarchive tracks
Postby Jin » Fri May 21, 2004 10:31 pm
I would be loving it, if you could introduce 2 keyboard shortcuts.
I am only running Metro SE. So the frequency of Archiving and Unarchiving tracks is a lot more than the full version users. But, it would be very convienient to hit "Command - A" for archiving selected tracks and "Command - U" for Unarchiving...
thanks,
-Joe I. Nelson "J.I.N."
Jin
Postby Jin » Fri May 21, 2004 10:46 pm
Command A.. was a bad example since that's generally used for Select ALL... But, hopefully my point got across..
thanks,
-Joe
Jin
Postby Scoot » Sat May 22, 2004 12:00 am
control/shift/a?
Postby Jerm » Sat May 22, 2004 9:16 am
Done! 8) ctrl-shift-u for unarchive and ctrl-shift-a for archive. This will be in the next release... 6.2.1
There is also a new contextual menu for the track window that allows easy archiving and unarchiving among other conveniences.
Postby Jazzdude » Sun May 23, 2004 6:23 am
Great idea!
I've been needing this, since I do a lot of
archiving and unarchiving. What I hate is when you go to archive
and you accidently release the mouse on unarchive (or vice versa).
This will be a time saver.
Thanks! :D
Jazzdude
