Sagan Technology Metro • View topic - increase the section's number of song's
Postby françois » Mon Feb 24, 2003 12:15 pm
could :?: you increase the number of song's in the section ?
for a live session, almost 100 songs will be nice, to have the choice
thanks
Postby Jerm » Sun Mar 16, 2003 1:29 am
As of 6.05i4 this feature request has been implemented in the full version only. Not in SE. You may have up to 25000 sections.
Note that in the OS X version 6.05i4 there is a bug (I think in the OS) that causes an out of memory error in Metro if you try to import a lot of MIDI files and the only way to increase the number of sections is to import MIDI files.
You may work around this bug by:
1. Import some MIDI files.
2. Save the file.
3. Quit.
4. Relaunch Metro or Metro G4.
5. go to step 1
This is fixed in 6.05i5.
