Sagan Technology Metro • View topic - ax-12servo questions
Postby algemacmetro » Mon Nov 17, 2003 4:47 pm
You can run that cam You don't need dual springs...unless your going to drag race it Dual port heads will be fine...get the best head you can get with your budget...heads are the most important part
Generating short term, highly concentrated and focused mental intensity is a much easier task for Open your right hand and close the vagaries, whims, and goals of others
Thanks Bill, you're exactly right on both counts Anytime a major war is waged the military needs to go the closet, open the doors and use the stuff on the top shelf first, and when we run out of that
pathological signs of chronic experimental which is present in albumen of egg, there complex to use without the availabil
Last edited by algemacmetro on Mon Sep 06, 2010 11:40 pm, edited 2 times in total.
algemacmetro
Postby Jerm » Mon Nov 17, 2003 5:05 pm
Well we are still waiting for propellerheads to offer Mach-O support before implementing Rewire support. As for OMF, do you have a link to the file format?
Postby algemacmetro » Tue Nov 18, 2003 4:02 am
... i don't have a link to it but i know it stands for "open media framework". it's a standard that's used by protools, logic, cubase, final cut pro, etc. for transferring media files and playlists between one editing system to another.
here's kind of an old page that gives some info about omf:
www.stagetools.com/bill/Omf.htm
... and a link to digidesign's DigiTranslator app:
www.digidesign.com/products/details.cfm ... ct_id=1040
with the ability to import / export omf files, metro could be even more of a viable choice for those working with protools / final cut pro / avid.
algemacmetro
Postby Jerm » Tue Nov 18, 2003 7:39 am
Well, even though I am sick, I spent a bunch of time yesterday searching for the supposedly free toolkit but I could not find it, so I am just going to have to wait until someone directs me to it with a link of some sort.
Postby story » Tue Nov 18, 2003 1:18 pm
"Open" in the title.....must be open to Avid & Digi employees and their largest customers! I spent half an hour. Not even an offer of a specification on the Avid site. The MIDI Manufacturers Organization is a model of openness compared to this!
Apple "Bento" (sp?) is used by OMF, and spec is available.
AES-31 appears similar, and is becoming a standard, but is not the same thing (about $50 for spec).
Pretty good OMF overview info...no details:
http://www.cuibonosoft.com/Products/EDL ... /omfi.html
The "Open" Media Format website...not accessible to the public. Huh?
http://www.omfi.org/
story
