Sagan Technology Metro • View topic - Version Numbers
Version Numbers
Version Numbers
Postby Scoot » Mon Sep 29, 2003 5:27 pm
Can the full version number be displayed in the opening splash window and the about metro box?
Seeing 6.1.0.1 is more reassuring than just 6.1 :D
"V 6.1.0.1" would fit in the current space.
If it's a release issue, the word beta or pre could be added.
It would help users tell you which version they are using when posting here.
Postby Jerm » Sun Oct 12, 2003 1:58 pm
The full version number can always be found in the finder's get info box.
Postby Scoot » Tue Oct 14, 2003 12:46 am
Jerm wrote:The full version number can always be found in the finder's get info box.
Yes.....it was more of a case of people with more than one version on a hard disk and actually knowing exactly which one is running, when they're wondering why they can't see new features or bug fixes.
I guess the best thing to do is have it so only one version can be opened at any one time and the others are .sit'ed
Postby Jerm » Tue Oct 14, 2003 12:53 am
To find out what version is running do this.
1. Find the icon in the dock and right click (or control-click) it.
2. From the popup select show in finder.
3.Type Command-I (or select get info from the file menu).
The version number is displayed. Alternatively step 3 may be unnecessary if you have the Metro folder viewed as a list and have the version number field enabled from view options in the finder.
