Sagan Technology Metro • View topic - clocks on transport window
Postby françois » Sun Aug 24, 2003 2:17 pm
would it be possible to define the transport window without the clock ( only remain the bars and beats ) ?
Postby Jerm » Sun Aug 24, 2003 2:30 pm
Why?
Postby françois » Sun Aug 24, 2003 2:35 pm
in some midiles songs on stage it would be better to not be disturb by the clocks just under the beats and bars.
it's just a suggestion....it would be interesting to reduce a the max the appearence of the transport window for live sessions.. ( hiding record, FF,RR .... )
Postby Scoot » Sun Aug 24, 2003 3:22 pm
If it's live why do you need the transport window?
I thought you setup all your tracks to begin with and just hit play and let it run through your list?
Postby françois » Sun Aug 24, 2003 3:29 pm
it's allright, but the song constrution of few songs is sometimes complicate, and I'm more sure to be on the good beat and bar by viewing them ... that's all.... for the rest that's ok, I increment the ram for amadeus application
have you open ichat sometimes ? I tried but you are always closed
Postby Scoot » Sun Aug 24, 2003 3:57 pm
françois wrote:have you open ichat sometimes ? I tried but you are always closed
sorry.....I'm spending a lot more time in OS9 at the moment and hence the reason ichat isn't on.
I find golive and photoshop quicker in 9 but metro has to be used in X cause it just works better. 8) .....and all the plugs aren't there in 9 hehe.
scoot
Postby Jerm » Sun Aug 24, 2003 6:05 pm
What you can do is place the transport so that the bottom half is off the screen. Then the only part that shows is the bar/beat position. Furthermore if you zoom the transport to the small size you can see just play, stop, record and the bar beat counter.
Postby françois » Mon Aug 25, 2003 12:41 am
on " special " I tried to zoom in / out, and nothing changes in the transport section.... could you tell me more ?
Postby Jerm » Mon Aug 25, 2003 2:00 am
In OS X click the green '+' (Zoom) button in the title bar
