Sagan Technology Metro • View topic - Some way to organize plug-ins.
Postby Scoot » Sat Jun 28, 2003 4:57 am
Metro finds the plugs-in available at startup.
Is there anyway to make them sit in user defined folders?
It would be a great way to shorten the list a lot. New folder - unused plugs, reverbs, EQ's........ 8)
Disable folder?
Postby Jerm » Sat Jun 28, 2003 10:19 am
Are you talking about the audio menu, plug-ins window or what? As you can probably see, I do not understand.
You can disable plug-ins by placing them in any folder with the word 'disable' in it. Metro will not find any plug-ins placed in a disabled folder.
For audiounits, the system does the searching and so it is not application defined.
Postby Scoot » Sat Jun 28, 2003 12:09 pm
Plugin window.
Damn!
Re: Disable folder?
Postby cornutt » Sun Jun 29, 2003 9:42 pm
I can envision something like the pre-OSX Extensions Manager. It finds all of your Audio Units and lets you build sets of them. It moves them back and forth between the regular folder and a "Disabled" folder depending on which set you choose. I might try writing something like that. Or maybe someone already has... let's go have a look at www.osxaudio.com.
cornutt
Postby Scoot » Mon Jun 30, 2003 12:43 am
hey cornutt......is there something at osxaudio.com we are meant to be looking at to solve the problem or was it a general comment?
Postby cornutt » Tue Jul 01, 2003 7:33 pm
Scooterman wrote:hey cornutt......is there something at osxaudio.com we are meant to be looking at to solve the problem or was it a general comment?
Just a general comment, a place to start looking. I'll do some searches.
cornutt
