Sagan Technology Metro • View topic - Rhythm Explorer Request(s)
Postby Qbert » Mon May 20, 2019 4:22 am
Hello Forum!
My first ever post so bear with me if some of this things have been suggested befor, sorry..
and thank you Jeremy for Metro andthis fantastic URE! -one of the best musical generators I have found. Good work! :D
My workflow is usually start with URE on a track (usual drums) som bars. Then another track with URE on bass etc.
I always keep the sequencer running an 'jam' out with generating new patterns, muting, unmuting etc.. and sometimes record this 'jamming' with Audio Hijack.
REQUEST:The nice thing would be to have a dedicated URE on every track. Maybe a little icon on the every track to open several UREs [with different colour? or track names in header?]. .. or simply that the URE remembers all its preferences/choices for the tracks when moving back and forth between tracks?
REQUEST2:Have the Patterns/Phrase/Lead - Density From To % moved to the front of URE so it is faster to experiment with more changes or less changes when generating new phrases and patterns. [actually I hope for more control parameters on the front page of URE :-) - for me it could be a much bigger window or that one could open the preference pages as its own windows, when experimenting with the parameters. Well no biggie request this one, but...
.. and while at the topics - I would like to see check boxes on the different functions of Derivation Magic Numbers so it will automatically calculate the correct Macic Number. Make it more esay to turn of wanted effects in the generating process (As of now a have a textpage up with all the function and its numbers and calculate the Magic number in the Derivation box):
:if this is correct?:
Bitwise Calculator:
1 Change Fixed Position 1 =1
2 Change Fixed Position 2 =2
3 Change Fixed Position 3 =4
4 Change Fixed Position 4 =8
5 Diddlyizer =16
6 Split =32
7 Join =64
8 Modify Bend =128
9 Add Members =256
10 Add Member =512
11 Subtract Member =1024
12 Add Member Special =2048
13 Subtract Member Special =4096
14 Rotate =8192
15 Reverse Direction =16384
16 Copy Last Beat =32768
17 Mirror =65536
18 Change Pitch =131072
19 Change Pitch 2 =262144
20 Change Pitch 3 =524288
21 Change Pitch To Octave 1 =1048576
22 Change Pitch To Octave 2 =2097152
23 Swap Pitches =4194304
24 Change Pitch To Sixth =8388608
25 Polyrhythms =16777216
26 Change Durations =33554432
27 Copy And Extend =67108864
28 Rebuild Durations =134217728
29 Expand With Random Rests =268435456
30 Modify Harmony =536870912
31 Shuffle Beats =1073741824
Example:
exs: 14 Rotate =8192
+ 17 Mirror =65536
=73728 (Derivation Magic Number to put in)
Ok for now, Thanks
S
Qbert
Re: Rhythm Explorer Request(s)
Postby Jerm » Mon May 20, 2019 11:56 am
Thank you for your feature request. I will review and respond in more detail soon.
Postby Jerm » Mon May 27, 2019 6:32 pm
Your magic derivative bit-wise calculations do look correct. One of the reasons they are not in a pop-up (or as you suggest, checkboxes), is that they are subject to change without warning and the current interface makes that relatively simple (just document differently). I do agree this would be better from a user perspective.
I am thinking about adding the ability of each track to retain URE data. The RE data would be saved when either new tracks are generated or when the RE preferences dialog's 'OK' is selected. The data would be written into the Metro document and read when the document is loaded. It would require a change to the database making all documents, written after implementation, incompatible with previous versions.
