Sagan Technology Metro • View topic - Enhancement idea: Paste And Paste again / Harmony
Postby Lytz1 » Fri Nov 02, 2018 5:26 pm
It would be awesome to see an implementation of the
Constrain pitches to marker chords(or Lead generator Scales) from the transpose menu
into the Paste and Paste again window:
when used in conjunction with Transpose after each paste,
the transposes can be constrained immediately, even when transpose-pasted over multiple chord changes/scales.
Obviously, this would also be pretty stellar in the Harmony window as well. Maybe even more so.
(i.e. 4 voice harmony lines can be instantly created over a Lead Generator line that uses multiple scales from chord-markers)
