Sagan Technology Metro • View topic - Transpose Window --> Constrain Notes to Track No. [x]
Postby Lytz1 » Sat Jan 27, 2018 10:30 am
We can already quantize a track rhythmically to another track. (Quantize window -> Quantize to track no. [x])
Why not do this also with note pitches?
The way I see this would be an addition to the Transpose window.
We have now: Conform to markers and Constain to scale.
In addition to that, why not something like: Transpose window --> Constrain to track number [x]
As a result, the notes would be forced to be transposed the notes of that particular "guide" track.
I think this would be quite useful and should be not too hard to implement?
(I think this might give impressive results when combined with a lead generator track as "lead note track."
Or when used simpler: Just as a chord guide track) Also would make it easy to change/adjust a lot of notes from different
tracks at the same time in a busy song
Re: Transpose Window --> Constrain Notes to Track No. [x]
Postby Lytz1 » Sat Jan 27, 2018 10:36 am
Hmm. Thinking about it, this might be more difficult as I thought.
Postby Jerm » Sat Jan 27, 2018 1:16 pm
I read your post twice and I do not understand the feature request. Please clarify exactly what this feature would do?
Postby Lytz1 » Sat Jan 27, 2018 4:48 pm
Okay, bear with me. I try to explain.
Scenario 1: We have a couple of notes selected on track 2.
What we already can do now in Metros Transpose Window is:
- constrain the selected notes to markers
- constrain the selected notes to a scale
Scenario 2: We have a couple of notes selected on track 2
What we already can do in Metros Quantize window is:
- Quantize the positions of the notes to another track, for example to the notes of track 1.
BUT: What we CAN'T do in Metro right now is this:
Possible Scenario 3: We have a couple of notes selected on track 2 and want to align the pitches of these notes to the
notes of track 1.
- We open the transpose window and select Constrain Notepitches to track 1.
(Track 1 would serve as a note grid. The notes of track 2 would be transposed to fit the note pitches of track 1)
In a nutshell: The same principle what quantize to track already does for note positions,
but for notepitches instead.)
Hope this explains it better?
Postby Jerm » Sat Jan 27, 2018 6:37 pm
Lytz1 wrote:Hope this explains it better?
Much!
Except what is align pitches? This has nothing to do with timing right? It would basically collect all notes from track 1 and any notes on track 2 that are not on track 1 would be transposed to the closest note. Is that correct?
Postby Lytz1 » Mon Jan 29, 2018 9:13 am
Yes, indeed that's exactly what I meant.
